Why is my laptop overheating within small usage of time.
Esta é uma boa pergunta?
@hannahanun could be a fan issue or could be an issue with the airflow. I suggest you disassemble your laptop and clean the fan as well as the air inlet slots etc. Since iFixit does not yet have a specific guide for that, use something like this video While you do this, make sure that your fan even comes on. Once you remove the bottom cover, turn it on and see if the fan kicks in. If not, replace the fan.
Also, consider replacing the thermal paste between the heatsink and the processor. For that use something like this guide How to Apply Thermal Paste Once cleaned, the fan inspected (or replaced) and new thermal paste applied, your computer should function at normal temperature again.
For as long as your computer continues to heat up, you are running a risk of damaging the processor etc. Do not use it until you got this fixed.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 27
