Ir para o conteúdo principal
O Lenovo Legion 5-15IMH05 é um notebook gamer criado para alto desempenho. Suas especialidades incluem jogos, programação e criação de conteúdo. Esta página do dispositivo ajuda os membros a identificarem seu modelo Legion 5 e a acessarem ajuda oficial e confiável em especificações técnicas, documentação de serviço e recursos de reparo para problemas comuns, como falha na bateria, superaquecimento, upgrades de armazenamento e problemas com o teclado ou display.
My Ethernet Connectivity Issue
For some reason my ethernet stopped working, I tried a new ethernet cable and different router and it was still not connecting. After further investigations about the problem, it seems that my laptop itself is the problem. It would only say "no connection" how do I fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @christianmamon
What is the status of the LAN network adapter shown in Device Manager?
Go to Device Manager - Network Adapters - right click on the LAN adapter entry - Properties - General - Device status box.
Does it say, "this device is working properly"?
To get to Device Manager in Win10/11 press the Win key and the x key (both together) and click on the Device Manager link.
If it is OK try resetting the TCP/IP stack and check if it works OK.
If there's a red cross next to the LAN adapter entry in Device Manager, right click the entry - Enable and check if it works OK.
If there's a yellow exclamation mark next to the LAN adapter entry in Device Manager, right click the entry - Update drivers and follow the prompts. You need to be online for this procedure to work. Try WiFi perhaps.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Hello! will this work the same with "no internet access" problem?
por
@christianmamon
Not sure what you mean.
The above is just checking if the LAN adapter on the motherboard is working OK so if it checks out OK and you have reset the network in the laptop, all you can do is try it and see.
Have you checked that there's no "bent" or missing pins in the Ethernet port on the laptop?
por
@jayeff I have, nothing is missing, though Im concerned that it keeps going back to identifying even if it connected earlier
por
@christianmamon
If the adapter status is OK and you have reset the TCP stack there's a problem on the motherboard as it isn't connecting to the router.
por
Adicionar a sua resposta
Christian Mamon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 55
Ao todo: 1,458
