Ir para o conteúdo principal
A SSL 2 é uma interface de áudio USB lançada em janeiro de 2020. Ela utiliza componentes de alta qualidade e é muito fácil de usar.
My line and Hi z button
When I press the buttons it makes static noise is there a way to fix this and how much or should I just buy a new unit
Esta é uma boa pergunta?
Pontuação 2
6 comentários
I noticed this on my SSL2 also yesterday, approx 2 years old, in daily use with a line input, but rarely adjusted. Even moving the switches a little side to side causes crackles. Sometimes I would take my hand away and it would be left sounding very degraded. Planning to check if this is just the channel I use, or both. The case is dusty so I might also try taking off the front plate and using an air duster spray in case anything got into the switch mechanism
por
Looking for spec on the buttons as I think I need to replace one
por
So you have n same problem with line buttons 🤔
por
@tim75649 i just did an overhaul as both my phantom power buttons were activating/deactivating with just the slightest touch. I re-flowed the solder joints and sprayed a bit of contact cleaner while I was in there. The combination seems to have solved the issue. For now. Di you have luck by just using the spray duster?
por
@petegunns i just did an overhaul as both my phantom power buttons were activating/deactivating with just the slightest touch. And every button was staticy. I re-flowed the solder joints and sprayed a bit of contact cleaner while I was in there. The combination seems to have solved the issue. For now.
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
It's dust I use vacuum cleaner to clear dust over knobs and buttons before I turn on it work no more cracklen 😁 but have to repeat as needed but crazy thing is my gear is always covered with plastic and blankets when not in use 🤔
Esta resposta foi útil?
Pontuação 1
3 comentários:
Hi @petegunns
It may be better not to cover in plastic or at least not plastic that is not the anti static type.
Most non anti static plastics can generate static electricity which attracts dust.
por
Even if it's the plastic it came in 🤔
por
@petegunns
Plastics that generate static attract dust so unless it is perfectly sealed it will get in somehow.
I would try an anti static cloth covering and check if that worked any better.
por
Adicionar a sua resposta
Pete Gunns será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 43
Ao todo: 1,158
