Ir para o conteúdo principal
Lançado em agosto de 2003. Um laptop caro, mas de alta performance para a sua época.
Why won't it boot up
press on button. green light comes on, screen flashes (sometimes) then it's dead
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Anything happen to it? Do you get any sign of the POST? What have you tired so far to fix it? Have your tried an AC adapter?
por Compartilhar
i'm back on with the machine in question maybe graphics card? don't know alot, is there some diagnostics i could run through it?
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
henge, you might want to check on here. Those Dells' are prone to failure, especially the hard drive. Check your RAM as well. Good Luck.
Esta resposta foi útil?
Pontuação 3
4 comentários:
came on after many attempts a month ago getting less reliable in switching on, runs great when its going but now it wont start. battery seems fine. thanks for takin the time.
por Compartilhar
Do any of your LED's come on or do they blink? Have you tried an external monitor to make sure that it is not just your LCD?
por Compartilhar
Here is the service manual for your computer http://www.elhvb.com/mobokive/edwin/lapt...
por Compartilhar
thanks for trying old turkey, I'll let it hibernate through summer and look for another.
por Compartilhar
Adicionar a sua resposta
henge será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 1,590
