Ir para o conteúdo principal
Guias de reparo e desmontagem para adaptadores de todos os tipos.
Mac ADC to DVI Adapter Power Failure - Repair?
For the old ADC Cinema Displays to work with many computers there is an adapter. Apple no longer sells them, and they are expensive. What happens about every 2 years is the power supplies go dead. I would like to know if anyone has repaired these by:
1. Replacing the blown component, or, my first choice,
2. Has anyone tapped in a 24v/5 amp power supply
Thank you so much
Esta é uma boa pergunta?
Pontuação 3
1 comentário
any chance you could post an image of the logic board with the bad component?
por
Adicionar um comentário
2 respostas
Solução escolhida
SlotcarBob, take a look at this site. It will provide you with a pinout of the adapter as well as give you direction in how to build your own adapter. Including the power supply. hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Great research to solve a recurring problem. +
por
it is best calble to send infor
Pontuação 0
Adicionar a sua resposta
SlotcarBob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 2,114
