Ir para o conteúdo principal
Charging port Type C
Good day hope everyone is okay. I would like to know if I wanted to to get some type C ports for this phone. Is it worth it just getting the port itself to soldering back on the board or is it best just to get the board that has the port already installed on it. Another thing which type of Type C port would be needed if taking the route of soldering. I have been looking around and seeing that there are different pins like 6 16 24 and so forth. How do I determine which is the correct
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@newuser49648 soldering a USB C port is really not a good job for somebody starting out. It is actually pretty difficult since there are pins on the bottom etc. I would suggest that you replace the complete charging board. It may be a bit more expensive but the success of getting a good repair is almost guaranteed.
Now, it you a really set in doing a solder repair You would need ports like this Just an example and not an endorsement for the seller.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
New User será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 485
