Ir para o conteúdo principal
O Western Digital My Passport Ultra é um dispositivo de armazenamento portátil USB 3.0 com capacidades de 500 GB até 5 TB.
Prying open hard drive
Hello - the actual external hard drive I have is a Western Digital easystore 2TB hard drive. The reason I chose the My Passport Ultra is because its practically the same size, form and shape as the easystore EXHD I have. Unfortunately earlier this year when I was getting my new computer all setup, I dropped this hard drive of mine on the floor as it was on top of the CPU. Now, the hard drive just makes a clicking noise every time I plug it in. I wanted to see if there was a way I can extricate the hard drive itself from the case and use a recovery reader I have . However, it seems impossible to do with no way to slither my way through the edge of the hard drive casing.
Imagem
Thank you
-Jordan
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
That's fairly risky if it is your first time. there will be tutorials available online. since it can be risky make sure to clone your drive before hand. a lot of free tools out there. you can use Remo Free Disk Clone Software if you want a fast and effective option.
However, I would insist that you simply just take it to a shop as a lot could go wrong here.
Esta resposta foi útil?
Pontuação 1
@jordan18927 yup, same tabs. You may just need to change the "angle of approach" and a bit more rigid tools. Check on here for the how-to proceed. this is just an example and not an endorsement
Pontuação 0
Adicionar a sua resposta
Jordan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 88
Ao todo: 1,793
