Ir para o conteúdo principal
Curva 1920x1080 144 Hertz Tela curva
My monitor will not display anything
One day I turned on my monitor and nothing will display. The PC detects the monitor; I have tried display and HDMI from the monitor; I tried all the HDMI and display ports on the PC, which other monitors work fine on; There is nothing showing when the menu buttons are pressed; I tried to shine a light on the screen and did not see any image.
I don’t want to just scrap it. I think it may be something wrong with the main board. I’ve ever only found one video where they replaced a chip on it to restore function. I was hoping to get some advice or suggestions. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@robertj30180 time to open it up and to look at the boards. Check for any obviously damaged components. Could be as simple as a failed component on the power or the video board. Until you look at it and check it out, it'll all be just a guess.
Since iFixit does not yet have a specific guide for this, use something like this video
Once you have it opened up take a good look at teh boards. Post some well focused pictures of those with your question. That way we can see what you see Adicionar imagens a uma pergunta já existente
While you work on your monitor, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 1
Try to unplug it, wait for 10 seconds, and then plug it back in from both ends. Let me know if it works.
Pontuação 0
Adicionar a sua resposta
Robert J será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 73
Ao todo: 1,364
