Ir para o conteúdo principal
Modelo A2159, EMC 3301. Uma atualização do MacBook Pro de 13" de nível básico. Disponível em Prata e Cinza espacial. Lançado em julho de 2019.
Original Battery not recognized
Hi,
I was assembling my macbook pro 13" 2019 and I have this problem: my macbook not recognized the original battery.
Have I damage the battery flex data cable? because, I pulled of this flex cable and I did not open the connector flex of the mainboard.
Photos:
Imagem
Imagem
Imagem
Thank you,
Update (05/03/24)
Continue:
The only way to turn on my macbook pro is: connecting it to the electical network with my power adapter.
Thank you
Update (05/03/24)
Hi Dan,
Photos:
Imagem
Imagem
Imagem
Imagem
Update (05/06/24)
Hi
I have already had a new flex cable !!! and I have just fixed my macbook pro !!!
Thank you for all answers !!
Esta é uma boa pergunta?
Pontuação 2
3 comentários
So the only way to use it is to plug it into the wall?
por
Exactly! That is the only way to use my macbook...
If I install Cocunut Battery... It will show "nan"
por
Both connectors seem to be fine and their tabs too, so is it possible that I have damaged the flex cable or the connectors of the mainboard?
I hope I have damaged only that cable...
por
Adicionar um comentário
1 resposta
Solução escolhida
Can you post images of both connectors so we can see if they are damaged. If it’s just the cable that’s replaceable MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
Imagem de Replace the small flex cable that connects the battery daughter board to the logic board.
Produto
$16.99
Esta resposta foi útil?
Pontuação 1
4 comentários:
Hi @danj,
Very close to being a short circuit between connector pins 9 and 10 (from the left) in the 2nd image posted above.
What do you think?
por
@jayeff - I would replace the cable for sure, but the real issue is what happed within the connectors.
por
@consu - Looking at the connectors they look OK, so maybe all you’ll need is a new cable! I wish you luck!
por
Thank you so much for your point of view!!
I will write here when I have the new Flex Cable.
por
Adicionar a sua resposta
Consu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 470
