Ir para o conteúdo principal
Informações de reparo e guias para a quinta geração do iPhone. Modelo: A1387
iPhone 4S No Backlight Issue
I have an old iPhone 4s that has no backlight, but if I hold it in light I can see the LCD working. I have tried restoring in iTunes and replacing the screen. There is gunk on the capacitors near the display cable so could that be it? If so, how can I remove it without knocking the components off the board? The previous owner had it sitting in a closet for years, so dust and gunk could have accumulated then.
EDIT: I don’t know what I did, but now the backlight turns on for a second showing the Apple logo, but then turns off again and won’t illuminate
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
could be a bad backlight filter
Update (04/20/24)
check that filter for continuity
Imagem
Esta resposta foi útil?
Pontuação 2
4 comentários:
How could I fix that?
por
@braydendcooper it requires microsoldering equipment its not an easy repair for just anyone. have you got a multimeter
por
Yes, I do have one
por
@tech_ni the filter has no continuity.
por
Adicionar a sua resposta
Brayden Cooper será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 462
