Ir para o conteúdo principal
Um celular intermediário da Realme, lançado em 14 de setembro de 2020. Equipado com Snapdragon 720G e até 8 GB de RAM com 128 GB de armazenamento interno, também possui uma tela Super AMOLED de 6,4".
power button and volume button also not working
Call is running baground power button is not working for switch off and volume button also not working
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
@jayarajtriparna is this a question or an answer? I am confused by this. If it is a question, let us know what make and model your phone is. Next, let us know what does not work and after that, let us know what you have tried. Give as much information as possible so we can try and help you.
por
@jayarajtriparna this was left as an answer to a separate question. It has been converted to its own question.
por
Speaker problem
por
Adicionar um comentário
1 resposta
@jayarajtriparna this "power button is not working for switch off and volume button also not working" sounds like a bad flex cable. The power button and volume buttons are on the same flex. Replacement flex cables are readily available at many online stores.
To replace the power button flex. Since iFixit does not yet have a guide for that , use something like the one For that use something like the one from here It was written in Spanish so use a browser that can translate it for you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jaya raj Triparna será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 51
Ao todo: 1,088
