power button not working
pls help me out
Esta é uma boa pergunta?
You should change the power button kit after opening it power button switch will cost you just 10rs you should go for it
Esta resposta foi útil?
Tôi nghĩ bạn nên làm điều này
how much would that cost btw?
@kxhbl8ukhdflfoj could be an issue with the actual power button not making proper connection with the switch. It is also possible that this is a bad volume & power button flex cable. Since iFixit does not yet have a guide for this, use something like this video or this one The second one is far more difficult since that applies a jumper across components.The repair flex cables are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Power boton not working
@rajubiswas39784 follow the directions given in my original answer
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 1,630
9 comentários
I inserted the speaker socket into my phone, and a minute later, the phone turned off and did not want to work. I tried cleaning the battery port and changed its screen, but it did not work either.
por Ahmed Waheed
Cara mengetahui kerusakan hp
por Erikson Farel
Camera problem
por deepak Chadar
@deepakchadar that is all you are going to give us? No make, no model. not telling us what the issues are, not telling us what you've tried, not telling us what you've checked? Only answer we can give you on this is replace the camera.
Once you add more information, we can always try and find a different solution but this is all we can do with what you gave us.
por oldturkey03
Battery chang
por shaikh Zeeshan
Exibir mais 4 comentários
