Se o telefone molhou e não digita, o que fazer?
Se o telefone molhou o que fazer para consertar o digital que travou por isso?
Esta é uma boa pergunta?
@alberteins74665 you will have to treat it just like any other water damaged device. For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Use these guides Xiaomi Mi Mix 2 for that. Remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors, assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave the parts to dry for very long. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. Always replace the battery on a water damaged device. It will fail sooner or later because of it. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@alberteins74665 terás de o tratar como qualquer outro dispositivo danificado pela água. Por agora, tens de parar de tentar carregar, sincronizar ou utilizar o teu telemóvel. Isto pode potencialmente piorar uma situação má. Isto pode danificar ainda mais o teu telemóvel.
O primeiro passo que eu daria seria desmontar o teu telefone. Utiliza estes guias Xiaomi Mi Mix 2 para o fazeres. Retira a placa principal e a placa de carregamento. Terás de retirar todas as protecções EMI. Se não as removeres, não estarás a limpar a placa.
Olha atentamente para todos os componentes e conectores e avalia os danos. Procura a corrosão mais grave, avalia os pinos dos conectores, etc. Examina todos os conectores, bem como as extremidades dos cabos. . Depois de limpares qualquer contaminação grosseira, utiliza álcool isopropílico a 90% ou mais e limpa as peças mais um pouco. Para uma limpeza adequada, utiliza o [guia|5825|este guia], que foi escrito para um Apple iPhone 3G, mas todos os passos são igualmente pertinentes para o teu telemóvel. Não posso sublinhar o suficiente a importância de uma boa limpeza, por isso faz isso várias vezes, substituindo o álcool após cada limpeza.
Não utilizes ar comprimido para a limpeza, uma vez que isso pode levar o líquido e as partículas de corrosão para áreas que mais tarde causarão problemas. Não precisas de deixar as peças a secar durante muito tempo. O álcool isopropílico, na concentração mais elevada, evapora-se rapidamente e dissipa a água.
O importante aqui é a limpeza. Não te esqueças de substituir a bateria. Não te esqueças de substituir a pilha. Isto é obrigatório e não uma opção. Se não tratares dela agora, ela vai falhar.
Depois disso, volta a montar o telemóvel e avalia-o novamente. Substitui sempre a bateria de um dispositivo danificado pela água. Mais cedo ou mais tarde, ela irá falhar por causa disso. Enquanto não limpares a placa e substituíres a bateria, tudo não passa de uma suposição. Lembra-te de que os danos causados pela água são os mais difíceis de resolver e reparar. Não importa se ficaste exposto durante 2 segundos ou 2 horas, o que importa é onde a água (partículas) causou os danos.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7
