Ir para o conteúdo principal
Guias de reparo para a linha de máquinas de lavar Kenmore 80 Series, fabricadas pela Kenmore.
No water while spinning
When spinning on rinse cycle the Water used to come on periodically for 3 or 4 seconds then shut off. My machine is not doing this anymore, otherwise it work fine
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @scott10453203
What is the model number of the washer?
por
Adicionar um comentário
1 resposta
If the water is getting in during other parts of the cycle, would indicate water valve is ok. If equipped , try selecting other cycle modes.. Hot vs Cold , Delicate vs Normal , try to make sure you are getting both Hot and Cold water in. If only one or the other temperature gets in , it is most likely the water valve. The other suspect if both temperatures work, would be the timer, not providing the electronic connections properly. This just general info without knowing your model Make / Model etc.. Good Luck.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Scott 104 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 241
