Ir para o conteúdo principal
Informações de reparo e técnicas para o Lenovo IdeaPad S510p, um laptop com tela HD de 15,6 polegadas, processador Intel Core i7 e armazenamento híbrido, lançado com Windows 8.1.
Wouldlike to replace right and left hinges.
Recently, the charging connector was pushed in and was not working. I took the laptop apart and fixed the problem., It now works find Escept I borke one on the hinge mounting hardware. I would like to fix this.
Glenn Moore
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
I think the part you want is under P/N: 90203870.
Esta resposta foi útil?
Pontuação 1
@glennmoore83502 and while you are looking for the hinges, download S510p Hardware Maintenance Manual to work on your hinges. Starting on page 60 and going through the LCD unit replacement also addresses the hinges.
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Pontuação 1
Adicionar a sua resposta
Glenn Moore será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 197
