Windows 7 screen resolution problem
I have an all-in one PC that had 32- bit Windows 7. But once I upgraded to the 64- bit version,the only available screen resolutions were 800x600 and 1024x768. MS-A923
Esta é uma boa pergunta?
Hi @pawelc
What resolutions were you getting with Win 7 32-bit?
According to the specifications, the AIO uses onboard video i.e. Intel Media Accelerator 3150 integrated in the Intel D525 CPU.
This only supports resolutions of up to 1366 x 768 for internal LVDS connections.
This is also the native resolution of the AIO display.
Have you got the Win 7 64-bit graphics drivers (example only) installed, to see if you can get to 1366 x 768 resolution?
Esta resposta foi útil?
@jayeff 800 x 600, 1024 x 768 even though it's widescreen. But it gets stretched out
@pawelc Have you installed the drivers?
@thequacker Yes and it worked!
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 51
Ao todo: 761
2 comentários
@pawelc you may need the 64bit display driver.
por oldturkey03 Compartilhar
It might just be simpler to upgrade to Windows 10? It handles drivers much better than W7.
por mike Compartilhar
