Ir para o conteúdo principal
Lançada em 2021, esta linha do F15 possui um processador Intel i5 ou i7, uma Unidade de Processamento Gráfico (GPU) NVIDIA GeForce RTX e uma tela de 15,6 polegadas com 1080p. Estes laptops têm um design elegante e hardware otimizado para jogos de alto desempenho a um nível de preço mais acessível.
Disconnecting Wifi and Bluetooth Automacically ,
Disconnecting Wifi and Bluetooth Automacically , even after reset the respected drivers , reinstallation of respected drivers , i tried everything by the help of youtube , but nothing helps .
" Disconnecting Wifi and Bluetooth Automacically occurs only whenever device is moved slightely " nothing happens when the device is remains in a same position !!!
this problem occurs only when the device is moved slightely or lifted or disturbed in its position !!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @deepak_
Do you mean that the WiFi and BT are just disconnecting or that they're intermittently not working anymore?
If just disconnecting try using the WiFi (or BT) as close as possible to your network router (or BT device) i.e <10cm and check if the connection remains stable.
If it does it may be a faulty antenna connection on the WLAN/BT card that is the problem.
If it still drops out or if it still fails etc it could be a loose or faulty WLAN/BT card.
Here's an image taken from this teardown video showing the location of the WLAN/BT card with the attached antennas.
Imagem
(click on image)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Deepak_M será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 349
