Ir para o conteúdo principal
Uma câmera digital point-and-shoot de 95,2 mm por 56,5 mm por 18,3 mm lançada em março de 2012.
pq minha câmera fica com uma luz laranja ligada?
eu fui num show esses dias e choveu muito, e acabou molhando a minha bolsa e minha câmera tava dentro, eu sequei ela assim q pude e tentei ligar, não ligou, aí coloquei ela no arroz e deixei alguns dias, depois disso ela ligou, mas ela fica com uma luz laranja acesa, e do apaga se tirar a bateria, a câmera liga, mas os botões não funcionam, alguém me ajuda por favor 😭😭😭😭😭
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@dudanuness you will have to treat your camera just like any other water immersed device. Just a reminder that the myth of rice as a tool for any kind of immersion accident has long been laid to rest as totally bogus. Rice does not work. It is the equivalent of doing absolutely nothing.
For now you want to stop continuing to try to charge, sync or otherwise use your camera. This potentially can make a bad situation worse.This may further damage your camera. The next thing to do is to clean it.
Disassemble your camera using Samsung DV300F these guides as well as this Disassembly Instructions Those are in English but I hope they are still useful to you as well. Now take all the circuit boards from your camera and remove any heatshiled that may be on those. After you have removed those, clean all of the boards, connectors and all with +90% isopropyl alcohol. Follow this guide and even so it was written for an Apple iPhone 3G all the points are still pertinent to your camera as well. While you clean your board, check for any obvious damage, like burned or missing components etc. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
When everything is properly cleaned, you must replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your camera and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Repair is War on Entropy!
Translation
@dudanuness terá de tratar a sua câmara como qualquer outro dispositivo imerso em água. Apenas para recordar que o mito do arroz como ferramenta para qualquer tipo de acidente de imersão já foi há muito tempo desmascarado como sendo totalmente falso. O arroz não funciona. É o equivalente a não fazer absolutamente nada.
Por agora, é melhor parar de tentar carregar, sincronizar ou utilizar a sua câmara. Isto pode piorar uma situação que já é má e danificar ainda mais a sua câmara. A próxima coisa a fazer é limpá-la.
Desmonte a sua câmara utilizando Samsung DV300F estes guias, bem como este Disassembly Instructions Estes estão em inglês, mas espero que também sejam úteis para si. Agora, pegue em todas as placas de circuito da sua câmara e remova qualquer placa de aquecimento que possa estar nelas. Depois de as ter retirado, limpe todas as placas, conectores e tudo o resto com álcool isopropílico a 90%. Siga este guia e, apesar de ter sido escrito para um Apple iPhone 3G, todos os pontos são pertinentes para a sua câmara. Enquanto limpa a placa, verifique se existem danos óbvios, como componentes queimados ou em falta, etc. Não posso sublinhar o suficiente a importância de uma boa limpeza, por isso faça-a várias vezes, substituindo o álcool após cada limpeza.
Quando tudo estiver devidamente limpo, deve substituir a bateria. Todos estes passos destinam-se a evitar uma avaria tardia causada pela corrosão. O melhor seria limpá-la com um aparelho de limpeza ultrassónico, mas se não tiver acesso a um, isto pelo menos ajudará. Depois de tudo isto estar feito, volte a montar a sua câmara e reavalie. Enquanto não for limpa, tudo não passará de um palpite. Mesmo com tudo isto, os danos causados pela água têm apenas uma pequena hipótese de serem totalmente reparados, mas pelo menos pode tentar.
A reparação é uma guerra contra a entropia!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
dudanuness será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 224
