Ir para o conteúdo principal
Informações de reparo para secadoras GE.
Why does my dryer stop heating?
My GE dryer stops heating but will start again if unplugged for a few seconds then plugged back into the outlet.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @anthony50477,
What is the model number of the dryer?
por
Adicionar um comentário
1 resposta
Sounds like a bad thermal cutout.
Think about it. It heats up, then stops, then starts again when it cools down.
It should do the same thing if you just shut it off rather than unplugging it.
It probably takes more than a few seconds.
If you must unplug it and it really just takes a few seconds, then I would suspect the control module.
Unplugging it is resetting it and it doesn't need to cool down.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Anthony será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 14
Ao todo: 264
