Waterproofing issue of moto edge 40
Phone in stable water for few seconds but touch, camera and fingerprint not working phone in warranty period also.
Esta é uma boa pergunta?
@ankitvishv26391 most warranty doesn't cover water damage. You are on your own with tis. It'll be up to you to either fix it or sent it to somebody to have it fixed. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if it was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit does not yet have a guide for this phone, use something like this video to help you disassemble your phone. Remove the main board and the charging board. You will have to remove all the EMI shields from the boards. If you do not remove the shields, you are not cleaning the board.
Take a careful look at all components and connectors and assess for any damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail later if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Replacement parts like your display (the touch screen is part of your display assembly), the camera and fingerprint reader are available if you feel like they need to be replaced.
As for any other repair, like a board level schematic etc, is not yet freely available
Esta resposta foi útil?
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 124
Duração total: 517
2 comentários
Speaker not clear sound
por Sachin Saini
@sachinsaini make and model of your phone? What have you checked? Is this new or has it always had bad sound? What have you checked?
por oldturkey03
