Ir para o conteúdo principal
Guias de reparo e suporte para a primeira geração da câmera compacta de alta performance RX100 da Sony, com sensor de 20,2 MP. A Sony Cyber-shot DSC-RX100 foi lançada em junho de 2012.
Dropped camera - not powering on
I dropped the camera without protection on stone floor. A small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much. The power isn’t turning on and when I try to charge it, no light is glowing. All mechanical components are operational and the battery looks intact. Any idea what the problem might be and if it is fixable?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@jacobvedholm this "small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much." we would have to seethe damage to evaluate it. If you have no power at all it is possible that you have a couple of torn/loose ribbon cables or worst case scenario; a damaged board. If it comes on but turns off it could be the lens. A lens that does not retract or extended will get the camera to turn off.
Adicionar imagens a uma pergunta já existente TO work on your camera you can download the SM from the Documents part on this page Sony Cyber-shot DSC-RX100 level 2 is the disassembly etc. and Level 3 are the schematics etc. Let us know and see what you find out
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jacob Vedholm será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 1,080
