Ir para o conteúdo principal
O Asus Q524U é um notebook/tablet conversível 2 em 1.
Can it be repasted?
My processor is constantly running at 100% and my laptop is getting very hot very quickly. I know Asus isn’t know for using good thermal compound and I’ve also had this laptop for around 7 years so either way, it’s due. Does it use standard thermal paste or something else like thermal pads?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @beardysteve
Looking at the image in Step.16 of the ifixit Substituição da placa-mãe do Asus Q524U guide, both the CPU and the GPU appear to have residues of have thermal paste on them.
Here's the ifixit Aplicação de pasta térmica guide that may help.
Imagem de Electronics Skills
Guia
Nível de dificuldade:
Moderado
5 - 20 minutes
Imagem de Asus Q524U Placa-mãe
Guia
Difícil
10 - 25 minutes
Esta resposta foi útil?
Pontuação 1
2 comentários:
That’s kind of what I thought. I just didn’t want to take my laptop apart without making sure lol
Thank you!!
por Compartilhar
@beardysteve
You may also have to check why the CPU is constantly running at 100% as this is unusual.
Go to Task Manager → Processes → CPU and check which process is causing the CPU to be operating at this level.
To get to Task Manager right click on the Taskbar.
If you meant the CPU fan then as you said the thermal paste may need refreshing
por Compartilhar
Adicionar a sua resposta
beardy_steve será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 34
Ao todo: 349
