Ir para o conteúdo principal
Informações de reparo para a Creality Ender 3 Pro--uma versão aprimorada da impressora 3D Ender 3, feita pela Creality. Lançada em setembro de 2018. Número do modelo: Ender 3 Pro.
Why isnt my 3d printer scrolling button working
Scrolling button from my 3d printer doesen"t work, is there any way I could fix that myself ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
hi,
when you say it doesn't work;
-it doesn't turn?
-it turns but no scrolling action of the screen?
Esta resposta foi útil?
Pontuação 0
3 comentários:
yes, it moves but it isnt shown on the screen
por
Most of these random - out of nowhere issues are commonly caused by firmware corruption. A simple reflash of the firmware usually does the trick. Have you done any modifications? if so, double check your connections.
-Double check the ribbon cable connection from the LCD to the main board.
-inspect for broken, loose , burnt components.
-reflash the firmware.
-When i started having issues with my ender 3(after 2 years of use) I upgraded the board with the SKR mini E3 . Not only did it solved all my issues but the printing quality and performance improved as well.
por
thanks for your help
por
Adicionar a sua resposta
guy with 3d printer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 526
