No image black screen
Esta é uma boa pergunta?
@cristinejo80172 you forgot to tell us if you have sound. Next turn your TV on Then use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obviously damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adicionar imagens a uma pergunta já existente for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
Esta resposta foi útil?
@oldturkey03 I have the same issue, and did the flashlight in a dark room.
Looks like a backlight issue. Any guides on how to replace it and what parts would be needed? Thank you!
yes me too can i get a guide on hoe to fix it
@rubimosqueda I bought new LED strips from Ebay.
And then followed these two guides from a youtuber.
Full black image
@venu72785 what have you checked and what have you already tried?
No enciende, estaba funcionando y se apagó y no prendio
Últimas 24 horas: 14
Últimos 7 dias: 58
Últimos 30 dias: 148
Ao todo: 5,243
13 comentários
por Edwin Lombeh
@edwinlombeh have you tried the steps listed in the answer?
por oldturkey03
the television does not turn on, but the power on light
por Dani Elsandi
No display only stay on
led indicator
por Dickri Adriana
Tidak ada gambar pas pakai sate box
por KEPETT
Exibir mais 8 comentários
