My dishwasher not drain
My Whorlpool Quiet Partner II will not drain?
Esta é uma boa pergunta?
most issue would be a blockage in the dishwasher’s filter. Or, you may have an issue with your dishwasher’s air gap, drain valve, drain hose or even your garbage disposal, causing your dishwasher to clog
Esta resposta foi útil?
I have the same problem. I have since had my garbage disposal removed. My question is how will I know if this solved the problem? Do I just run the dishwasher and hope for the best?
Hi,
There’s information about this here, in the iFixit site.
https://www.ifixit.com/Troubleshooting/W...
You should be able to find your issue and hopefully resolve it.
Hope this helps
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 659
Hi @scotthaithcock,
What is the model number of the dishwasher?
por jayeff
