Memory card is not reading
Camera is not reading the memory card
Esta é uma boa pergunta?
@santhoshvk try a different memory card and make sure that the one you have is compatible with your camera. Only CFexpress cards can be used. Also, you need to format the card before it can be read. Follow the Canon Directions for that.
If you have the right card and it is formatted correctly but it still does not work, check the pins of the card reader. Make sure those are not bend broken or otherwise damaged.
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 32
Ao todo: 348
