HP Laserjet 2055d leaves two black marks at the back of the printous
my HP Laserjet 2055d leaves two black marks at the back of the printouts.
i have completely replaced the pickup assembly unit but with no avail.
anyone can help
Update (01/18/24)
but just wanted to let you know that i have already tested several toners.
i also have completely replaced the whole pickup assembly picture attached.
and have cleaned all the rollers inside the machine.
Esta é uma boa pergunta?
3 comentários
@nick what do you make out of this? Roller assembly issues? @shockwell let's see if the printer guru can help you out with this.
por oldturkey03
and have cleaned all the rollers inside the machine. [image|3199582][image|3199583]
por Saman
The HP Laserjet 2055d, much like a skilled artist, uses an intricate interplay of components to create its prints. At the heart of this process is the toner cartridge and the transfer belt2. The toner cartridge contains the ink that the printer uses to create images and text, while the transfer belt helps to apply this toner evenly across the page3. If either of these components is damaged or malfunctioning, it can result in unwanted marks appearing on the printouts.
por Kamran Waiz
