Ir para o conteúdo principal
Domine o multitarefa com o Yoga Slim 7 Pro. Este laptop ultra fino de 14″ repleto de estilo é potente, oferecendo o desempenho ultrarrápido dos processadores móveis AMD Ryzen™ série 5000, combinado com visuais impressionantes em OLED 2.8K opcional, longa autonomia da bateria e uma variedade de recursos inteligentes que ajudarão você a aproveitar ao máximo o seu dia.
My Camera Stopped Working
My camera randomly stopped working and my system says it is not connected. I have tried several software solutions but I think I might need to open it up and reconnect something...where can I find a guide to doing this? Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @ombreviews
Here's the hardware maintenance manual for the laptop.
Go to p.66 to view the procedure to remove the camera.
If the cable connection seems OK and the camera module needs replacing search online for either 5C20X55554 or 5C20X55556 to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
2 comentários:
How can I check the connector on the motherboard? Before removing the screen or anything like that. I wasn't seeing anything in the manual for that. Thanks so much!
por
@ombreviews
Not sure with your model but nowadays a lot of the connections between the camera/microphone in the lid and the motherboard is done by a USB connection between the motherboard's IO chipset and a USB controller in the camera/microphone module. The two data wires for the USB are in with the video cable and not a separate cable.
All you can do is check how many cables come from the lid to the motherboard. Most likely there'll be the WiFi antennas connected to the WLAN card and a video cable and that's all.
You would really need to have the schematics for the motherboard to know exactly how it is connected.
I couldn't find a free schematic download online but if the board model number is an NM-D231 then you can purchase it here and it will show the wiring details
por
Adicionar a sua resposta
OMB Reviews será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 596
