Ir para o conteúdo principal
Screen coming loose from keyboard
Hi! So excited to be using this site for the first time. The lower right corner of my screen is coming loose from the upper right base of my HP laptop. I can see a wire from the screen to the base. On the base, I can see the top part lifted from base. This has slowly gotten worse over time to now I don’t close the laptop anymore. Thank you!
Esta é uma boa pergunta?
Pontuação 0
6 comentários
Hi @ilav,
What is the model number of the laptop?
por
Hi @jayeff! I am away from my PC today and will provide tomorrow. Thank you!
por
Hi Ila, please provide a picture so I can see how your computer looks like, with the picture, please send me the model of your computer. Thanks.
Sincerely,
San.
por
@jayeff HP Laptop - 17-by3065st
por
@sanchittiwari HP Laptop - 17-by3065st
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
Hi @ilav
Here's the maintenance and service guide, taken from this support webpage for the laptop.
Go to p.65 to view the procedure to remove the display assembly.
This will allow you to check if the hinges are screwed securely to the base enclosure and also the lid.
If the hinges are damaged and need replacing, their part number is Item #4 on p.22. Search online using the part number only, to find suppliers that suit you best.
Note: You can't add images to a Comment, only to your question or to an answer. Here's how to do it in ifixit Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
3 comentários:
@jayeff Thanks for the detailed response. I reviewed the maintenance and service guide which is very helpful. I am terrified to give this a try for many reasons (like why do I have to remove the optical disc?) but will give it a go. Accepting your answer after I post this comment.
por
@ilav
You have to remove the optical disc i.e. dvd drive so that you can remove the base cover as some screws are hidden by the drive when it is in position
The dvd drive is a sealed unit so it's not a problem unless you drop it on the floor ;-)
Good luck. It's not as hard as you think. Just make sure that you follow the procedure especially about removing the battery as you don't want any problems happening with the battery connected to the motherboard when using tools inside the laptop
por
Hi. I had the same issue about a year ago, probably since the time this comment was posted. But I kept using it with a bit more care, But it popped off a screw at a given moment out of nowhere. I havnt been brave enough to mess with it because I dont know what Im gonna find and if im gonna be able to put it back together. But the answer sounds good enough, maybe I'll give it a try. Thank you
por
Adicionar a sua resposta
Ila V será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 845
