Ir para o conteúdo principal
Lançado em 2020, o modelo Razer Blade 15" Advanced foi projetado para oferecer aos gamers especificações poderosas e uma estética elegante.
GPU seems to be faulty
In daily use including with an external screen the machine works.
As soon as you try to run an game that puts pressure on the GPU or a benchmark FURMark the game or the benchmark starts, but then the entire machine freezes up.
We've tried every combination of drivers and resets we can think of. Does this sound like a hardware fault?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have the same issue with my laptop from ebay, but when i was changing the thermal paste i noticed the VRM thermal pads were bone dry, maybe this is the issue ???
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @brianoflondon,
Did the game play OK before?
If it is a new game does the laptop meet the minimum system requirements of the game?
Have you tried testing the memory either with the Windows memory diagnostic tool or perhaps a standalone memory test to make sure it is all OK?
Gaming stresses all the hardware not just the GPU.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Brian of London será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 436
