Why battery draining down fast
Battery draining fast
Esta é uma boa pergunta?
Hi @aijazahmed
Try replacing the battery and check if that resolves the problem.
Here's a video that shows what to do.
Search online for B-H0 battery to find battery suppliers that suit you best.
Esta resposta foi útil?
First, check if the battery is bloated or not if it is bloated change it with a similar 4500mah battery.
If the battery is not bloated first change the app's background running setting to off from setting and stop other background processing you don't want.
Next, stop all unnecessary notifications and turn on the dark mode it boosts your phone battery life.
If it didn't work try replacing the battery and check if that resolves the problem.
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 79
Ao todo: 2,768
9 comentários
Battery drains fast I am vivo phone
por kishore kishore
@kishorekishore How old is your battery? Is this something new or has it been getting steadily worse? Have you considered @jayeff's advice to replace the battery?
por Jerry Wheeler
Battery drain fast
por Hashir Siddiqui
Battery draining issue
por Gangadharaiah R
Very bad battery
por Saguna Raghav
Exibir mais 4 comentários
