Ir para o conteúdo principal
The Samsung Galaxy M31 is an Android smartphone which was released in march 2020. Model: SM-M315F/DSN
mergulho na água celular
Como recuperar celular que caiu na água?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@estacioguim8059 For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit does not yet have a guide for the teardown or the boards, use something like this video to help you disassemble your phone. remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors. Truly assess the damage. Look for corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Your phone uses a separate charging board. I would go ahead and replace that as well as the battery. Both parts are known to fail later due to corrosion damage.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Translation
@estacioguim8059 Por agora, deve parar de tentar carregar, sincronizar ou utilizar o seu telemóvel. Isto pode potencialmente piorar uma situação má. Isto pode danificar ainda mais o telemóvel.
O primeiro passo que eu daria seria desmontar o telemóvel. Uma vez que o iFixit ainda não tem um guia para a desmontagem ou para as placas, utilize algo como este vídeo para o ajudar a desmontar o telemóvel. Terá de remover todas as protecções EMI. Se não retirar as protecções, não está a limpar a placa.
Observe atentamente todos os componentes e conectores. Avalie verdadeiramente os danos. Procure a corrosão, avalie os pinos dos conectores, etc. Examine todos os conectores, bem como as extremidades dos cabos. Depois de limpar qualquer contaminação grosseira, utilize álcool isopropílico a 90% ou mais e limpe as suas peças mais um pouco. Para uma limpeza adequada, utilize o [guia|5825|este guia], que foi escrito para um Apple iPhone 3G, mas todos os passos são igualmente pertinentes para o seu telemóvel. Não posso sublinhar o suficiente a importância de uma boa limpeza, por isso faça-a repetidamente, substituindo o álcool após cada limpeza.
Não utilize ar comprimido para a limpeza, uma vez que isso pode levar o líquido e as partículas de corrosão para áreas que causarão problemas mais tarde. Não é necessário deixar secar durante um dia. O álcool isopropílico na concentração mais elevada evapora-se rapidamente e dissipa a água.
O importante aqui é a limpeza. É claro que o melhor é mandar limpar por ultra-sons Não se esqueça de substituir a pilha. Trata-se de uma obrigação e não de uma opção. Se não a substituir agora, a bateria irá falhar. O seu telemóvel utiliza uma placa de carregamento separada. Eu substituiria essa placa, bem como a bateria. Ambas as peças são conhecidas por falharem mais tarde devido a danos por corrosão.
Depois disso, volte a montar o telemóvel e faça uma nova avaliação. Enquanto não limpar a placa e substituir a bateria, tudo não passa de uma suposição. Lembre-se de que os danos causados pela água são os mais difíceis de resolver e reparar.
Enquanto trabalha no seu telemóvel, tire muitas fotografias. Quando terminar, tire essas fotografias e crie um guia para o iFixit. Isso ajudará a próxima pessoa que tenha o mesmo problema que tu. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit vai ficar agradecida.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
estacioguimaraesbentesguimarae será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 44
