Ir para o conteúdo principal
Lançado em 30 de novembro de 2022, na versão de lançamento de 16 GB ou 64 GB, com uma caneta Basic ou Premium, respectivamente. Ele também possui a maior tela de qualquer tablet Kindle até hoje, com 10,2 polegadas.
How can I get battery replacement and replace it?
My Scribe is 1 year old and I abuse it pretty much daily. I read on it for about 8-10 hours a day and take notes on it too during the class, which is about 90 minutes per class (I have 8 classes). The heavy note taking is not my concern, it's the reading. I usually charge mine from 40%-80/85% like everyone suggested, but lately I see a difference in the battery's capacity and I have been charging it more often than usual. I know it's a pretty new device, but how can I get a new battery and replace it myself? The device seems to be fragile too, unlike paperwhite
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @apcsila
Here's a video that may help.
Take note that the screen is not held down by adhesive but rather it is clipped on instead, so perhaps the best method of removing it is to use some pry tools (examples only) to remove it from the base. Read the last comment posted below the video about the removal procedure.
As for the battery, searching online for Amazon (or Kindle) Scribe 2022 battery produces no results for suppliers of the battery, but perhaps you may be able to find a supplier once you have opened the tablet and found the battery model number (printed on the battery) and search for the battery model number instead. It is shown at 3:50 minutes into the video but it is too small and fuzzy (when enlarged) to make out what it says.
Imagem de Assorted prying tools for all types of enclosure opening, cable unhooking, digitizer removal and more. A complete set of opening tools all in one kit, perfect for electronic repairs. For professionals and beginners alike.
Produto
Prying and Opening Tool Assortment
$9.95
Esta resposta foi útil?
Pontuação 2
1 comentário:
A eso lo llamas un video para "ayudar" a reemplazar la batería? Más bien lo llamaría destrozar completamente el dispositivo. Ese video solo ayuda a saber como no abrirlo.
por
Adicionar a sua resposta
apc sila será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 18
Últimos 30 dias: 71
Ao todo: 2,533
