Ir para o conteúdo principal
Informações e guia de reparo para a geladeira Kenmore 596.7857*80*, um modelo de geladeira com freezer inferior sem recurso de gelo na porta, equipada com degelo automático e chave de resistência anticondensação. Esta página abrange informações para números de modelo que correspondem ao padrão 596.7857*80*.
Not getting any ice
I have not been getting any ice, I have moved the shut off arm up and down a few times and waited 24 hours for it to make ice and have not gotten any ice. I don't know where the water filter is located so I haven't changed that. Any help you can give me is greatly appreciated. thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @edbakey
If there is no water/ice in the ice maker or if it is not working, first check if the freezer door switch is electrically OK and not that one set of contacts in the switch is corroded etc..
By design the ice maker does not function when the freezer door is open.
The freezer door switch is a changeover type switch which when the freezer door is opened, it releases to turn the freezer light on and the ice maker off and when the door is closed it re-operates to turn off the light and reconnect the power to the ice maker. It is the ice maker that turns the water inlet solenoid valve on and off as required.
Be safety aware if you decide to test if the switch is OK as there is 120V AC on the switch. It may be safer to disconnect the power to the refrigerator and use an Ohmmeter instead.
If the switch is faulty, search online for 12002646 to find suppliers that suit you best.
If the water inlet valve is faulty, search online for WP67003753 to find suppliers that suit you best.
Imagem de Controls the flow of water into your refrigerator for ice-making and water dispensing functions.
Produto
Whirlpool SxS Refrigerator Water Inlet Valve - WP67003753
$73.99
Imagem de Activates the interior refrigerator light when the door is opened.
Produto
Whirlpool Door Switch - W11396033
$27.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ed Bakey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 261
