Ir para o conteúdo principal
A 6ª geração de smartphones Moto E. Números de modelo XT2005-1, XT2005-3, XT2005-4 e XT2005-5.
What did I do wrong?
I thought I could take the phone apart and put it back together again but now it's stuck in some sort of boot loop and if it isn't in the loop I just see N/A in the corner. Did I break something or did I just forget to plug something back in?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@green36821 just to clarify, there were no issues with this phone prior to the disassembly. It functioned as should and now it does not. If that is correct, it sounds like there is either something that is not connect right. You will have to open it up again and check all the connection. Make sure they are properly seated and that there are no bend or broken pins.
It is also possible that this is a software issue. Which is less likely since your phone worked before, Let us know what you find out.
Esta resposta foi útil?
Pontuação 0
1 comentário:
so i took it all apart looked at everything and nothing seemed broken and its all plugged in but its still doing the same thing. is there anything else i should try or should i bite the bullet and bring it to a shop?
por Compartilhar
Adicionar a sua resposta
Green será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 268
