Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Android Samsung Galaxy Note20. Lançado em agosto de 2020.
How to fix Jamed volume button
How do I fix the jammed volume button on Galaxy note 20
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @katelyngolden
Here's a teardown video that shows how to open the phone to gain access to the Power button so that it can be checked or replaced if necessary.
The Power button removal procedure is explained between 6:25 and 6:35 minutes into the video.
If the Power button actuator is broken and needs to be replaced, search online for GH98-45544A (mystic black), GH98-45544B (mystic grey), GH98-45544C (mystic white), GH98-45544D (mystic bronze) or GH98-45544E (mystic green) depending on the colour of the phone, to find suppliers that suit you best.
Here's the ifixit Samsung Galaxy Note20 guide, that may also help.
Esta resposta foi útil?
Pontuação 1
If you're not ok with opening your phone.you can try using IPA/rubbing alcohol and use a Q-tip that soaked with IPA and try rubbing the button.thats what works for me.
Pontuação 0
Adicionar a sua resposta
Katelyn Golden será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 390
