Ir para o conteúdo principal
All wireless functions lost
Hi, my Bose Soundlink work fine when plugged into the laptop jack (whether switched on or off!) but all wireless funtions have stopped working. As I used to use these with my iphone via Bluetooth, how can I figure out if it's a charging issue, or a problem with Bluetooth? Hope you can help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@tim75247 since it "work fine when plugged into" but not with wireless I would start with a new battery. IF it still does not work, then you will need to tear it down further and check the circuitry. The battery should be in the Left side. You should have 4 screws under the ear cushion. 2 of those are regular Philips head screws and two are proprietary safety screws. You may need to try different screwdrivers for those (T5) to see if you can remove those.
If you are stuck with anything post a couple of pictures with your Question of where you are stuck at and hopefully we can assist you further, Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tim será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 265
