Ir para o conteúdo principal
Display is not comming.
Power is on, sound is comming but Display is not comming.
Esta é uma boa pergunta?
Pontuação 1
4 comentários:
Ashish, what's the model number of your television? There are so many differences between TVs that we need to know what we're working with in order to help.
por
@ashish58011 As Jerry asked, what is the brand and model of your television? If you shine a flashlight onto the display, can you see a faint picture?
por
The screen is not showing but sound is comming
=== Update (11/08/25) ===
Yes the screen is not showing
por
@dharshandaya did you take the time to read the answer? Have you tried those thing? what was the outcome?
por
Adicionar um comentário
1 resposta
@ashish58011 First you need to verify that you have no image on all inputs. Try all of those. If it remains dark, unplug everything that is plugged in the back of your TV. unplug the TV and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adicionar imagens a uma pergunta já existente for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Yes, We still need to know what exact Model your Vu television is.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ashish será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 61
Ao todo: 869
