Ir para o conteúdo principal
O Asus VivoBook 15 F512 foi lançado em 2020 e é desenvolvido pela empresa Asus. Esta página contém informações sobre como reparar o notebook Asus.
Internal display not working
Display not working. When I connect with HDMI cable with monitor that is ok.
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
The internal display does not turn on, but the external display works when connected via HDMI. Sometimes the internal display turns on but then turns off again, which is very rare.
por Compartilhar
@tuhinnathsarkar
See the answer below.
Try moving the lid slowly back and forth yo see if you can make the display come on and go off. If you can it may be a loose or faulty video cable between the motherboard and the LCD panel
por Compartilhar
Adicionar um comentário
2 respostas
Hi @tapasmahata
Switch the display back to the laptop screen and then shine a flashlight at an angle close to the laptop screen and check if you can see any images at all on the screen. They will be very faint if they are there so trying this in a darkened room may help.
If you can see images, then there's a backlight problem with the display. Either a faulty backlight power supply on the motherboard, a faulty video cable/video cable connection between the motherboard and the screen or a faulty screen
If you can't see any images, then it is either, a faulty video cable/video cable connection between the motherboard and the screen or a faulty screen.
Esta resposta foi útil?
Pontuação 0
Screen flickering problem
Pontuação 0
Adicionar a sua resposta
Tapas mahata será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 679
