58pus8545 no image on the screen
(Also dutch but wil reply in English)
I have the same TV with the same problem. My description;
Moving ambilight LEDs, which apparently respond correctly when we browse through the menu with the remote control. But no image on the screen. When starting up, you sometimes see some vague backlight on-off switches, but otherwise it seems as if the backlight of the display panel is not functioning. Has been playing since purchase and has now gotten progressively worse. In the past it has always been solved by switching it off and on again up to 10 times. Two times there was some purple image distortion. But usually just no/black image at all..
Based on this description;
the Philips assigned Repair Company “cerepair” told me that the parts likely needed to fix this (buffer board?) would likely not be available. I recieved an offer to a new similar TV, but it does not feel right.
What can i do instead of buying new Philips TVs that end up on the garbage pile within 3 years?
I want something that is repairable and supports a circular economy.
Esta é uma boa pergunta?
@holland91713 does this "browse through the menu with the remote control" mean you can see the menu,even when your screen does not display anything else?
Right now, it does not seem to matter which brand of TV's we buy. They all seem to fail pretty quick. Philips is not a bad brand (no worse than the rest) but what is important is the possibility to repair those TV's. If they make service manuals and schematics available, at least those devices can be repaired. Companies like Toshiba, Vizio, and the cheaper store brands like TCL, Hisense etc in general do not. Toshiba is paranoid and utilize an army of lawyers to prevent repair (That is a brand nobody should ever buy) and the rest just considers their TV's as disposable. At least with Philips, Samsung, and others like Panasonic you have a chance of getting service documents, which will help. They are not really supportive of repair but are the lesser of the evil.
Philip is just weird about their manuals. you can never find them by your model number. They go by chassis number. Like in the case of your TV it is a TPM20.1E LA chassis
por oldturkey03
