Ir para o conteúdo principal
A impressora sem fio de formato amplo Small-in-One Expression Photo XP-960 coloca a impressão de fotos com qualidade profissional ao seu alcance.
Replace waste ink pads
My Epson XP 960 display warned that the printers waste ink pads are at the end of their life cycle and needed to be replaced. I ordered and installed a new a complete ink pad kit but the printer still prompts that the ink pads need to be replaced. The installation was done correctly but the printer is stuck on the warning .
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
@pauljustyna see if this video will help you out. It may be possible that you need to reset the waste ink counter after having replaced the waste ink pad pads. See if this procedure will resolve this.
Esta resposta foi útil?
Pontuação 2
Furthermore you need to reset the waste ink tank counter via software, with WIC or another similar software.
Pontuação 0
1 comentário:
@jallroad that is correct. The video actually makes mention of it and shows how to install it.
por
Adicionar a sua resposta
Paul Justyna será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Ao todo: 2,399
