Ir para o conteúdo principal
O HP Pavilion x360 14 (especificamente o 14-dw1010wm) é um laptop 2 em 1 versátil com tela multitoque de 14 polegadas com rotação de 360º, processador Intel de 11ª geração e placa gráfica Intel Iris Xe. Ele vem com memória RAM DDR4, um SSD M.2 NVMe e uma bateria de polímero de íon de lítio de 3 células e 43 Wh.
Screen replacement for x360
Hey everyone hope you are having a good day, has anyone ever replaced a screen on a HP Pavilion x360 ? If you could please show me a video or link a replacement that would be more than great!!
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Hi @brandontunnell,
Please confirm the full model number of your laptop as shown on the product info label on the bottom of the laptop?
por Compartilhar
hp pavilion x360 14dw1013tu
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi @brandontunnell
Here's the maintenance and service guide taken from this support webpage for the x360 14dw1000 series laptops.
Go to p.51 to view the procedure to remove the display assembly. On p.53 the LCD panel is being removed.
Also on p.53 you'll find the HP part numbers for the LCD panels that can be used. Usually the part number is somewhere on the back of the panel if you wish to verify which one you have now. Search online for the part number only to find suppliers that suit you best.
p.s. If you post the product number of the laptop (also on the info label) I may be able to find the part number for the screen so that you can order it before having to disassemble the laptop to find out what it is.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Brandon Tunnell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 48
Ao todo: 1,348
