Ir para o conteúdo principal
Guias de reparo e instruções para o MacBook Pro 13" com Apple Silicon de 2ª geração (chip M2) e tela Retina de 13,3". Modelo A2338. Lançado em 15 de julho de 2022 na WWDC 2022, junto com o MacBook Air M2.
Screen Problem, blurred lines at bottom of screen.
Hello,
My Mac have developed some blurring at the bottom on the screen. It covers the entire width of the screen and is about 1/4" high.
I took it into Apple and they said it needed "screen controller" repair costing about $600.
Has anyone else had this issue and was able to perform a fix themselves.
Thanks
Andrew.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Sadly its out of warranty !!!!!!
por
Adicionar um comentário
2 respostas
Ouch! Your system should still be under warranty!
Double check if it is, then go to anther Apple store or dealer as this should be a free repair!
Unless there is visible damage around the displays chin area I can’t see any reason to be denied.
Esta resposta foi útil?
Pontuação 0
2 comentários:
por
@andrewusherwood - If its just outside the window by a few weeks I would still press Apple, But you need to lean on them a bit. Be pleasant but firm, escalate it up the food chain, I'm sure you should be able to get this fixed for free!
por
I have the same problem, just just happen just I made an upgrade to Sonoma, I a few weeks after. Now, I don't know if its is hardware problem, or is it an software/driver issue. How can I tell, and take appropriate. I reverted to the original OS that come with the laptop, but the issue still persist.
Hope some can help..
Thanks
Pontuação 0
1 comentário:
@georgetuges - Plug in an external display, if the image is clean on it, it tells us your internal displays logic is damaged and you likely need a new display assembly.
por
Adicionar a sua resposta
Andrew Usherwood será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 1,010
