Ir para o conteúdo principal
Mid-range phone released September 2019. Alternatively named Redmi K20 Pro in China and India. Features 6.39″ Super AMOLED display, Snapdragon 855 chipset, 4000 mAh battery with 27W fast charging, under-display fingerprint reader, motorized pop-up selfie camera, and a main camera with 48 MP plus an ultrawide 13MP and a 8MP telephoto lens.
23 Perguntas Visualizar todos
My phone fell in water and from that time display stopped working
Actually I was moving on bike to my friends home I was in some sort of speed I didn’t see the pit on the road and my phone fell in water from my pocket and first half an hour the screen worked after half an hour some sort of Glenn lines appeared on the screen after some time totally phone display has gone but I am receiving calls and notifications and alarm but the display is off I am unable to use my phone so please help me I found this website is very useful and getting immediate response so I came here while searching out online for my phone so I hope the best THANK YOU
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @nivasreddych
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Mi 9T Pro guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nivas reddy ch será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 38
