Ir para o conteúdo principal
O Samsung Galaxy A22 5G é um smartphone Android intermediário desenvolvido e fabricado pela Samsung Electronics como parte da série Galaxy A. O celular foi lançado pela primeira vez em 24 de junho de 2021. O celular vem com um sistema de câmera traseira tripla e um display eletrônico de 90 Hz. A bateria tem 5000 mAh, o que é 62 % maior que a bateria do iPhone 13 Pro.
Why does my volume button does work?
I been having these difficulties in past 3 months that my up and down volume doesn't work any more?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @juanmigueldoton,
Has the phone been dropped or gotten wet at all?
por Compartilhar
Yes it's I've been drop it many times but It didn't get wet
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi @juanmigueldoton
Dropping a phone certainly doesn't so it much good.
It may be that the volume problem is caused by a loose or faulty power and volume flex cable (part # GH81-20712A) or perhaps a faulty power/volume control button (supplier example only to show the button)
With regards to the other problem you're having with the headphone jack, it could be a faulty headphone jack. There's an internal spring that signals the audio control when a plug has been inserted into the jack so perhaps its intermittently operating when it shouldn't be. If this is the case then the jack would have to be replaced as it cannot be repaired. The good thing about this is that the jack is on the charge port board which is a separate module so it's easy to replace once the phone is open. The part number for the charge port board is GH81-20699A.
To find suppliers for the parts search online using the part number only. Couldn't find a part number for the control button so if it is faulty search for Galaxy A22 5G power/volume control button.
Here's a teardown video for the phone which may help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
JuanMiguel Doton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 317
