I have a black screen problem
The laptop turn on but I can't see nothing except the black screen, how can I fix it
Esta é uma boa pergunta?
Hi @rees95027,
Try connecting an external monitor to the laptop's vga port or mini DP port and check if you get a display on it after starting the laptop. Don't forget to press the F7 (or Fn + F7) key to toggle the display between laptop only, external only or both on together.
If there is a display on the external monitor, then switch the display back to the laptop screen and then shine a flashlight at an angle close to the screen and check if you can see any images at all. They will be very faint if they are there so trying this in a darkened room may help.
If you see images on the laptop screen then there's a backlight problem. Either the backlight power supply on the motherboard, the video cable between the board and the LCD panel or the LCD panel.
If there are no images on the screen, then there's a problem with the video cable or the LCD panel
If there's no display on the external monitor, then either the laptop's not passing POST (Power On Self Test) on startup or there's a motherboard problem.
Here's the hardware maintenance manual for the laptop that may help if you have to disassemble it.
Esta resposta foi útil?
Maybe it's just the connector of the display which needs to be firmly pressed into the socket. All the best from Bayern, Shadow_I
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 38
Ao todo: 1,098
3 comentários
Hello Sir can you tell me? here are some issue i have Lenovo laptop x250 i5 5th gen. issue is dim screen how to i fix it
por Brothers Technology
Hi @brotherste23795
Depends what you mean by "dim".
Have you tried pressing the Fn + F6 keys (both together) a few times to see if the screen brightens?
If it doesn't brighten then you may have a backlight problem.
por jayeff
It only shows it's charging but its just black like no sign of power on I gave it to a guy to fix it but to no vain I'm really frustrated I end up removing the ram and hard drive 😞
por Mzondi Gumbo
