I have no spark and no fuel pump prime
Car had bad wiring before and figuring it all out. Main relay was tested= good, fuses were tested= good, fuel pump was tested=good, the distributor is brand new along with the spark plugs and wires. Grounds are good to the battery terminal/transmission , thermostat housing, and valve cover. Car dash lights come on and car cranks. Check engine light stays on, I get no codes thrown when tried to flash for codes.
Esta é uma boa pergunta?
2 comentários
Would that be the same for a 93? Sorry just making sure
por Onii Chanz Compartilhar
@oniichanz
Yes is is for years 1990-1993
por jayeff Compartilhar
