Ir para o conteúdo principal
The second generation Integra was introduced in April 1989 and in this generation, one of the first VTEC engines ever manufactured by Honda was installed in a JDM Integra DA series.
5 Perguntas Visualizar todos
I have no spark and no fuel pump prime
Car had bad wiring before and figuring it all out. Main relay was tested= good, fuses were tested= good, fuel pump was tested=good, the distributor is brand new along with the spark plugs and wires. Grounds are good to the battery terminal/transmission , thermostat housing, and valve cover. Car dash lights come on and car cranks. Check engine light stays on, I get no codes thrown when tried to flash for codes.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Would that be the same for a 93? Sorry just making sure
por
@oniichanz
Yes is is for years 1990-1993
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @oniichanz
Here are some images from the 1990 Acura Integra repair manual showing the ignition circuit and the fuel pump circuit, that may help.
(click on image)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Onii Chanz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 41
