Ir para o conteúdo principal
Lançado em maio de 2018, esta é uma versão de lançamento plus do Samsung Galaxy A6, atualizando a tela de 5,6" para 6,0" e a câmera de 16 megapixels para uma câmera de 24 megapixels.
The charging jack problem
The charging jack of my phone is damaged and the charging keeps shaking when I plug in the charging cable.The charging jack of my phone is damaged, it keeps shaking when the charging cable is connected, how can it be fixed, please help me.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Rohit, unfortunately your charging jack is mounted directly on the motherboard so unlike other Samsung models, there isn't a separate part that can be replaced to fix the charging port.
I'm afraid you're going to have to find someone experienced in microsoldering who can remove and replace that tiny port from your motherboard. I consider myself fairly talented at soldering but I would hesitate to attempt this one on my own; if you're not really good at it I wouldn't recommend trying to fix it yourself.
The closest I can come to offering you help is this guide showing you how to remove the motherboard so you can get to the charging jack, but after that I'm afraid you're on your own.
Manuales / Samsung Galaxy A6+ / Motherboard
Otherwise the only thing you could do would be to replace the entire motherboard, which is basically going to be the same as replacing the whole phone.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Hi @rohitsaxen93718,
Here's the part number for the charge port connector - 3722-003954
Search online using the part number to find suppliers that suit you best
por Compartilhar
Adicionar a sua resposta
Rohit Saxena será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 759
