Ir para o conteúdo principal
The Xiaomi Redmi Note 11 Pro is a mid-range smartphone by Xiaomi released January 2022. It has a 6.67" Super AMOLED display, a 108 MP main camera, a side-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Mediatek Helio G96.
Why is my REDMI NOTE 11 stuck on a boot loop?
(I have REDMI NOTE 11 not REDMI NOTE 11 PRO) So about a month ago I dropped my REDMI NOTE 11 into the sea and after taking it apart and drying it I put everything back together and turned it on. I thought it would work but it was stuck on a boot loop. I tried every method I could find and nothing worked. I saw some lime on screens wire also lime on where the wire goes. Maybe thats the problem? Im thinking on getting a new screen and thing where the wire goes but Im not sure that will help. Is there any way of getting it out of the boot loop?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Hi mate, try to press and hold volume up and power button untill it gets you to boot menu. When you get there try your volume up and volume down button and check that they are working properly. A common issue is that volume down button is stuck and is permanently on and when you try to boot the phone it does permanently force restart. If everything is ok with your buttons, try to select wipe cache and then reboot the device. If problem remains, then if you don't care enough of your data you could try factory reset from the same menu as i mentioned before. Note that the device will boot as new but it will be locked with your gmail account.
Esta resposta foi útil?
Pontuação 0
2 comentários:
What do I do if the volume down button is stuck?
por
سلام
اگه دکمه ها درست کار نمیکرد با یه دستمال تینری خوب تمیز کن و دوباره چک کن
یک بار هم بدون فلت پاور چک کن ببین روشن میشه اگه روشن شد فلت پاور تعویض کن
por
@simas17599 your worries should not be about the boot loop but on how to get your phone cleaned after the water immersion. You said you dropped it "into the sea", which makes me think that you immersed in into salt water.
First and foremost, stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.
Salt Water is corrosive and will get your components to corrode very severely. The very first step I would take is to disassemble your phone. Use this guide for the charging board and this one for the main board. Once you have to boards removed, take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. This "lime on screens wire also lime on where the wire goes" is a telltale sign of corrosion and salt water damage.
I suggest that you clean your boards and all ribbon cables a couple of times with sterile water, not drinking water (that might have helped right after it got submerged in the salt water). Use a soft brush and clean it very, very thoroughly with the sterile water. With the amount of corrosion that I envision, you will have to remove all the EMI shields of your main board. Once you got all of the gross contamination cleaned, use 90%+(as high as you can get) isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning. That can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. If you can get it professionally cleaned, than do so. This is not an easy task and you may need to consider professional help for an ultrasonic cleaning. After you cleaned it, replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Then reassemble your Xiaomi and re-evaluate. Until it is cleaned, everything will only be a guess. It is very possible that you have a bad LCD and replacing the display assembly will most likely be a must do. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Imagem de iPhone
Guia
Repairing iPhone Liquid Damage
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de Xiaomi Redmi Note 11 Pro Charging Board
Guia
Xiaomi Redmi Note 11 Pro Charging Board Replacement
Moderado
40 - 50 minutes
Pontuação 0
hi!
i dont know professional skills, but my dad had the same problem. try to knock it a little bit, on table and with your hands. i watched it on this yputube page and it worked: ***https://www.youtube.com/watch?v=JQWMCeM0...
Pontuação 0
Adicionar a sua resposta
Simas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 47
Ao todo: 2,053
